Valve cover gasket for Generator - 91WL
04-10-2007, 21:17
I have the manuals from my blue box for a 91 wide body PT40- It states that
the PTS/MH15 engine number is a V1902BG volts 120/240 Hz 60 Kw 15 Phase 1. Call me at 704-5281893 for any more information I can glean from the book. john redden 91PT-40 ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
04-11-2007, 00:45
My 15KW Powertech is powered by Kabota. I'm surprised Powertech did not
have the info for you. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL -------Original Message------- From: rogerwwebb Date: 04/11/07 07:52:47 To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Valve cover gasket for Generator - 91WL I need to identify the part number and source for the valve cover gasket on my generator engine. The generator is a 15Kw Power Tec, however, neither Power Tec, nor Bluebird can tell me what brand of engine it is, nor have I found a tag on the engine for identificaton. Does anyone have this info, or do I need to custom make one? Roger Webb 91WL Cedar Rapids, IA [Non-text portions of this message have been removed] |
04-11-2007, 00:51
gasket on my generator engine. The generator is a 15Kw Power Tec, however, neither Power Tec, nor Bluebird can tell me what brand of engine it is, nor have I found a tag on the engine for identificaton. Does anyone have this info, or do I need to custom make one? Roger Webb 91WL Cedar Rapids, IA |
04-11-2007, 00:58
Roger
As I recall the information with my 91, it's a Kubota engine. I can check model number this weekend if you need it. Mike Bulriss - going to the LSB Rally this weekend 1991 WB40 "Texas Minivan" San Antonio, TX -- In WanderlodgeForum@yahoogroups.com, "rogerwwebb" wrote: > > I need to identify the part number and source for the valve cover > gasket on my generator engine. > > The generator is a 15Kw Power Tec, however, neither Power Tec, nor > Bluebird can tell me what brand of engine it is, nor have I found a tag > on the engine for identificaton. > > Does anyone have this info, or do I need to custom make one? > > Roger Webb > 91WL > Cedar Rapids, IA > |
04-11-2007, 02:04
the PTS/MH15 engine number is a V1902BG, volts 120/240 Hz 60 Kw 15
Phase 1. >> The info above provided by John Redden is what I needed. PowerTech confirmed the Kubota engine (V1902BG) and Kubota also confirmed the engine was used with PowerTech generators in the Wanderlodges. The gasket is available from a Kubota distributor here in Minneapolis (where I happen to be today) and I will pick it up this afternoon. Thanks for your help. Roger Webb 91WBWL Cedar Rapids, IA |
04-11-2007, 02:49
Kubota makes engines for many applications. you need the complete
engine number for many things that vary on a particular engine model. It helps to clean out the screw socket and clean the v cover screws prior to torquing the new gasket. a dirt filled socket will bottom out the screw prior to compressing the gasket. If you use brake cleaner to blast out the socket, oil the solvent out so it wont dry out the gasket in that spot. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "rogerwwebb" > > the PTS/MH15 engine number is a V1902BG, volts 120/240 Hz 60 Kw 15 > Phase 1. > >> > The info above provided by John Redden is what I needed. PowerTech > confirmed the Kubota engine (V1902BG) and Kubota also confirmed the > engine was used with PowerTech generators in the Wanderlodges. > > The gasket is available from a Kubota distributor here in Minneapolis > (where I happen to be today) and I will pick it up this afternoon. > > Thanks for your help. > > Roger Webb > 91WBWL > Cedar Rapids, IA > |
04-11-2007, 04:07
The V1902 engine is a 4cyl 1.9 liter Kubota that is also used in Skid
Steers and tractors. Specifically it is used in the L3450 Kubota tractor. Just go down to your local Kubota dealer and tell them you want a valve cover gasket for an L3450. Take your valve cover with you to verify fitment. This is good because there prices are usually less and they typically will have items like that in stock. Good Luck! PS. Kubota diesel engines are some of the finest diesels available. Parts and engine replacements are readily available and they are very durable. I have owned multiple kubota engines with more than 10,000 hrs including one that was at 12,500 hrs and still going strong. Thomas Houston, TX 83' FC35 84' FC33 [Non-text portions of this message have been removed] |
