Tooo much voltage!
02-26-2007, 14:07
Tooo much voltage!
Ron,
Yes, I have done that on our last BB and on our boat. Ample Power has a routine to modify the regulator that will remove the built-in reg. and bring out the field wire. I think you'll need to email David Smead or others at Ample Power since I don't know if it is to be found on the website. David is the owner/designer/engineer of the place and sometimes is not available. Good luck. Let us know how it turns out if you do it. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: ronmarabito2002 To: WanderlodgeForum@yahoogroups.com Sent: Monday, February 26, 2007 2:14 PM Subject: [WanderlodgeForum] Re: Tooo much voltage! Thanks Dick: Can you use the same alternators and simply remove the built-in regulator? R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com "Richard Hayden" > > Ron, I've had good luck with these on boat and bus.. > > http://www.amplepower.com/products/ns2/index.html<http://www.amplepower.com/prod\ ucts/ns2/index.html><http://www.amplepower.com/products/ns2/index.html<http://ww\ w.amplepower.com/products/ns2/index.html>> > > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > ----- Original Message ----- > From: ronmarabito2002 > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, February 26, 2007 8:02 AM > Subject: [WanderlodgeForum] Re: Tooo much voltage! > > > Jeff: Not sure that I agree with you on internal. I have lost 2 > regulators recently and it is a royal pain in the *&%$ to get to under > the bedroom floor. I think I'm going to explore external regulators > that are convenient to replace. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > --- In WanderlodgeForum@yahoogroups.com "Jeff Miller" > wrote: > > > > Does this coach have the remote regulator or alternator with internal > > regulator? > > > > If remote, I'd suggest replacing it with internally regulated. It can > > be fixed as-is, but an open circuit between the regulator and the > > coach can cause the regulator to see no voltage and go to full output. > > > > - Jeff Miller > > in Holland, MI > > > > > > --- In WanderlodgeForum@yahoogroups.com "webdarn" > > > > > > About two years ago, my 82 35 FC began cooking my batteries with > > over > > > 16 volts. I removed the alternator and regulator and the alternator > > > shop bench tested both and found no problem. After reinstalling, > > > still over 16 volts. > > > I bought a programable Xantrex regulator and everything worked fine > > > for two years, now nothing. I plugged the wiring to the origiinal > > > regulator back in and the old problem is back, 16.1 volts. > > > Any thoughts? > > > > > > Andy Clayton > > > '82 35FC > > > > > > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
02-26-2007, 16:48
Tooo much voltage!
Thanks Dick. I'll get a hold of him.
R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Richard Hayden" > > Ron, > Yes, I have done that on our last BB and on our boat. Ample Power has a routine to modify the regulator that will remove the built-in reg. and bring out the field wire. I think you'll need to email David Smead or others at Ample Power since I don't know if it is to be found on the website. David is the owner/designer/engineer of the place and sometimes is not available. > > Good luck. Let us know how it turns out if you do it. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > > ----- Original Message ----- > From: ronmarabito2002 > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, February 26, 2007 2:14 PM > Subject: [WanderlodgeForum] Re: Tooo much voltage! > > > Thanks Dick: Can you use the same alternators and simply remove the > built-in regulator? > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > --- In WanderlodgeForum@yahoogroups.com "Richard Hayden" > > > > > Ron, I've had good luck with these on boat and bus.. > > > > > http://www.amplepower.com/products/ns2/index.html<http://www.amplepower.com/prod\ ucts/ns2/index.html><http://www.amplepower.com/products/ns2/index.html<http://ww\ w.amplepower.com/products/ns2/index.html>> > > > > > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > > > ----- Original Message ----- > > From: ronmarabito2002 > > To: > WanderlodgeForum@yahoogroups.com > > Sent: Monday, February 26, 2007 8:02 AM > > Subject: [WanderlodgeForum] Re: Tooo much voltage! > > > > > > Jeff: Not sure that I agree with you on internal. I have lost 2 > > regulators recently and it is a royal pain in the *&%$ to get to under > > the bedroom floor. I think I'm going to explore external regulators > > that are convenient to replace. > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > --- In > WanderlodgeForum@yahoogroups.com > "Jeff Miller" > > wrote: > > > > > > Does this coach have the remote regulator or alternator with > internal > > > regulator? > > > > > > If remote, I'd suggest replacing it with internally regulated. > It can > > > be fixed as-is, but an open circuit between the regulator and the > > > coach can cause the regulator to see no voltage and go to full > output. > > > > > > - Jeff Miller > > > in Holland, MI > > > > > > > > > --- In > WanderlodgeForum@yahoogroups.com > "webdarn" > > > > > > > > About two years ago, my 82 35 FC began cooking my batteries with > > > over > > > > 16 volts. I removed the alternator and regulator and the > alternator > > > > shop bench tested both and found no problem. After reinstalling, > > > > still over 16 volts. > > > > I bought a programable Xantrex regulator and everything worked > fine > > > > for two years, now nothing. I plugged the wiring to the origiinal > > > > regulator back in and the old problem is back, 16.1 volts. > > > > Any thoughts? > > > > > > > > Andy Clayton > > > > '82 35FC > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > [Non-text portions of this message have been removed] > |
02-27-2007, 03:25
Tooo much voltage!
Andy,
Check price at fleetsource dot com. Howard Truitt, 86 PT40, Camilla, Ga. ----- Original Message ----- From: williama_clayton To: WanderlodgeForum@yahoogroups.com Sent: Monday, February 26, 2007 7:34 PM Subject: [WanderlodgeForum] Re: Tooo much voltage! --- In WanderlodgeForum@yahoogroups.com, "Andy Clayton" wrote: >My local heavy duty alternator dealer suggested to replace the old alternator and external regulator (both obsolete) with a new Leece- Neville 160 amp. Cost over the counter is $375.00 plus tax. Does this sound about par? Andy Clayton '82 35 FC > My alternator has an external voltage regulator that is mounted above the > batteries and has a small harness connecting it to the alternator. I > unplugged the original two years ago and installed the Xantrax regulator. > It worked fine for two years, now nothing. > > Andy Clayton > '82 35FC > > __________________________________________________________ > Refi Now: Rates near 39yr lows! $430,000 Mortgage for $1,399/mo - Calculate > new payment > http://www.lowermybills.com/lre/index.js...=lmb-9632- 17727&moid=7581 > ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.412 / Virus Database: 268.18.3/697 - Release Date: 2/22/2007 [Non-text portions of this message have been removed] |
