Fan blade torque?
10-14-2006, 05:24
Fan blade torque?
After removing the shroud on the '87 FC the fan blade
dominates and seems that it needs to be removed to access anything well. I am thinking the position should be marked in case a balance issue for an exact replacement and the (6) fan bolts torqued to 40-60 lbs. Any comments, TIA Bob Janes, 87FC35, Greenville, SC |
