Entry door jammed....HELP!
08-28-2006, 12:20
Went to get the Bird tonight, and the latch on the entry door seems
jammed. When I try to pull it, the handle doesn't come out like normal. It's almost like the little handle lock is locked, but I have never used that lock, only the deadbolt. Of course, all windows are shut up tight, so I can't crawl in. Suggestions? Scott Forman 82 FC35RB Memphis |
08-28-2006, 12:38
Hope you have a key for the "automotive" door lock... The button may
have been pressed (without your realizing it). Sometimes, you need to push the door shut (real hard) to unlock if it's partially opened. Hopefully, that is the problem and not the automotive door lock. Some folks have put various products around the plunger to keep it from locking --- best approach I heard was a short piece of clear plastic tubing. Personally, I'm a lock paranoid so I lock both the dead bolt and the automotive lock. Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 4203 El Sobrante, CA On Aug 28, 2006, at 5:20 PM, Scott Forman wrote: > Went to get the Bird tonight, and the latch on the entry door seems > jammed. When I try to pull it, the handle doesn't come out like > normal. It's almost like the little handle lock is locked, but I have > never used that lock, only the deadbolt. Of course, all windows are > shut up tight, so I can't crawl in. > > Suggestions? > > Scott Forman > 82 FC35RB > Memphis > [Non-text portions of this message have been removed] |
08-28-2006, 13:02
Scott,
I too only use the dead bolt, but have always kept the key for the other lock on the ring for just this reason. I'm unsure if your 82 is the same, but on my 91 WL, the sliding window on the door can be disassembled. There are screws on the window frame, you can take off one side (the side facing to the rear) and slide out the glass, then reach in. The screws are located near the top and bottom corners and under the weather stripping filling the channel of the frame. The weather stripping can be moved up, and then down a bit to reach the screws. Not the easiest thing to do, but at least you'll get access to the inside door handle and the automotive door lock. Again assuming your windows are set up like mine. Hope this helps. Roger Webb, 91 WL, Cedar Rapids, IA --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Went to get the Bird tonight, and the latch on the entry door seems > jammed. When I try to pull it, the handle doesn't come out like > normal. It's almost like the little handle lock is locked, but I have > never used that lock, only the deadbolt. Of course, all windows are > shut up tight, so I can't crawl in. > > Suggestions? > > Scott Forman > 82 FC35RB > Memphis > |
08-28-2006, 13:18
you can dissamble a window then reassmlbe it after entry itis only 2
screws and no damage to the windowif you absolutely have to get in that way if you want hrlp give me a call I can talk you throug it Stephen 77 fc 35 905 328 0162 --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Went to get the Bird tonight, and the latch on the entry door seems > jammed. When I try to pull it, the handle doesn't come out like > normal. It's almost like the little handle lock is locked, but I have > never used that lock, only the deadbolt. Of course, all windows are > shut up tight, so I can't crawl in. > > Suggestions? > > Scott Forman > 82 FC35RB > Memphis > |
08-28-2006, 13:37
Had the same problem but the door latch was NOT locked. The Bargman
entry latch often has a problem with a pin that retains a spring. If the pin is worn out when you pull on the latch nothing happens. I was at a rest area and could not get out of my unit. Kept trying and it finally opened. I removed the latch and installed a machine screw in place of the pin. Bargman makes a kit for the door lock or you can buy a new assembly for about $50.00. If you get in to your unit and it still does not open a few phillips screws will give you access to the innards. Bruce 1988 FC25 |
08-28-2006, 13:50
Personally, I think it locks backwards, Pull out=lock,
push in =unlock, less chance of accidentally locking when you step out to kick the tires. If you have lock-out coverage, might be better to call them. Bob Janes '87FC35 Greenville, SC --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > Had the same problem but the door latch was NOT locked. The Bargman > entry latch often has a problem with a pin that retains a spring. If > the pin is worn out when you pull on the latch nothing happens. I was > at a rest area and could not get out of my unit. Kept trying and it > finally opened. I removed the latch and installed a machine screw in > place of the pin. Bargman makes a kit for the door lock or you can buy > a new assembly for about $50.00. If you get in to your unit and it > still does not open a few phillips screws will give you access to the > innards. > > Bruce 1988 FC25 > |
08-28-2006, 20:29
Aren't those locks common on most rvs? If so- a key could be bought from an
rv dealer as they have master keys. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
