Timeout! Was - Re: Strange Lever
08-19-2006, 05:59
All righty, play time is over - everyone back to their respective
corners.
Shessh, just when the new guy said their was no flaming here.......
and he is right about that.
Bill, go get a Dead Frog Pale Ale. Mike grab a Point Ale. Stephen
get a LaBatts Blue and quit egging it on. Oh yeah, I love the
regional brews!!
Thank you. Now go back to work on your Birds!
Mike Bulriss - Moderator
1991 WB40 "Texas Minivan"
--- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs
> Hmmm would love to invite you Mike, anytime, we can show you a real
"GOOD TIME" LOL
> Bill 84FC35SB from the west coast
> Stephen Birtles wrote:
> Bill do you think we should invite mike up here for a
holiday between
> the east coast and the west coast we could drive him completely around
> the bend
> Stephen 77fc35 from the east
> --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein"
> <MHOHNSTEIN@> wrote:
> > You seem to be a little too critical. I believe I said, "works like
> electric trailer brakes "IN A WAY" and I have one more reason to hate
> Canada.
> > MH
> > ----- Original Message -----
> > From: Wilhelmus Schreurs
> > To: WanderlodgeForum@yahoogroups.com
> > Sent: Saturday, August 19, 2006 10:19 AM
> > Subject: Re: [WanderlodgeForum] Re: Strange Lever
> > Mike:
> > Not so at all.
> > Electric trailer brakes actually has a puck that rubs on the drum
> which is attached to the brake shoes, which in turn stops the trailer,
> so electrical/mechanical/mechanical, yuk, lots of wear and maintenance.
> > With the Jacob's driveline retarder, it is electricity which
> creates a magnetic field to slow down the vehicle. there are no
> rubbing parts. Maintenance is very simple, cleaning, checking of
> contacts and greasing.
> > One thing which Jeff Miller alluded to, there is no connection
> between the driveline retarder and the rest of the system ,
> acceleration or braking. Gosh one of the things when I get my BB home,
> I will look at installing circuitry that will either allow the brake
> to be applied or disengage it when the throttle is applied.
> > Bill
> > 84FC35SB
> > Terrace, B.C.
> > Mike Hohnstein <MHOHNSTEIN@> wrote:
> > That would be one way to characterize the down grade retarder. It
> functions like electric trailer brakes, in a way.
> > The well marked grease zerk, if not covered with road grime is a
> critical maintainence point. I'm greatful that my retarder works
> pretty well so far, my chassis has roughly 170k miles.
> > Mike Hohnstein
> > Germantown WI, Myrtle ID
> > 83FC35rb
> > From: Scott
> > Sent: Friday, August 18, 2006 11:25 PM
> > Subject: [WanderlodgeForum] Re: Strange Lever
> > So this thing is like a driveline breaking system?
> > Scott Waldy
> > '83FC35SB
> > Boise, Idaho
> > --- In WanderlodgeForum@yahoogroups.com, "Scott"
> > wrote:
> > > Lots of great posts on the Jacobs Driveline retarder. (that is what
> > is
> > > on our coach 86FC) BUT no one mentioned the need to grease the
> > bearings
> > > inside. When we got ours you could not even tell it had a grease
> > > fitting. Find it on the side of the retarder. Use a GOOD HIGH TEMP
> > > GREASE. I grease mine pretty frequently.
> > > I did the dummy thing last year on the way to RIV and left it one
> > by
> > > mistake when entering the highway, thought I was draging an anchor,
> > > (actually felt like a fuel filter cloggin up) It got hot and
> > smelled,
> > > when shot with a temp gun it was just over 300* got back underway
> > in a
> > > hurry and got air to it. No harm works fine. I use it in stop and
> > go
> > > traffic, to limit the use of the service brakes. Works great for me.
> > > ScottB
> > > 86FC 4sale
> > > SC
> > wrote:
> > > > I have a Strange Lever mounted to the side of the shifter box.
> > The
> > > > lever goes into a small black box with numbers on the side. As
> > the
> > > > lever is pulled down, the numbers increase and the lever is
> > > internally
> > > > notched to stop on each of the numbers. Any clue?
> > > > Scott Waldy
> > > > '83FC35SB
> > > > Boise, Idaho
> > [Non-text portions of this message have been removed]
> > Share your photos with the people who matter at Yahoo! Canada Photos
