Stand Up Antenna
06-08-2006, 08:37
Stand Up Antenna
I just completed repairing the stand up antenna broken lift legs,
replaced the 12v/ground connectors at the lift motor, pulled the new wiring down through the old path, installed a new AntennaCraft antenna. Everything is working fine, great reception. Interesting...on the upper dash there are two antenna switchs mounted horizontal one above the other. They are double throw momentary switches. Lifting the antenna requires pushing one side of both switches. Lowering the antenna requires pushing the other side of both switches. Nothing happens pushing only one switch. Anyone know why there are two switches? Bluebird overkill? -- Curt Sprenger 1987 PT38, Anaheim Hills, Calif. |
