Kohler genset tripping
03-19-2006, 12:04
Hi, finally time to get back to the genset trip problem.
I noticed the fan isn't turning and after a short time the red reset
button trips.
The fan seems to turn easily by hand. Any suggestions on what would
cause the fan not to turn?
thanks
Rose Mary
82 FC 33
Hoping to go for a jaunt in the 'White Bird' toward the end of next
week.....
03-19-2006, 12:27
Rose Mary, if your circuit breakers on the control box are tripped- you will
have no power to make your fan turn. Ernie-83pt40 in Texas
-----Original Message-----
Sent: Mon, 20 Mar 2006 00:04:33 -0000
Subject: [WanderlodgeForum] Kohler genset tripping
button trips.
thanks
Rose Mary
82 FC 33
week.....
Yahoo! Groups Links
03-19-2006, 13:49
Awhile back my fan stopped turning. i removed the cover on the back of the motor
and one of the screw terminals had cbroken loose probility from corrosion. the
208 volts comes directly off the out terminals in the control box on mine
re brake 1983 fc-35 sb
-------------- Original message from erniecarpet@...: --------------
button trips.
thanks
Rose Mary
82 FC 33
week.....
Yahoo! Groups Links
YAHOO! GROUPS LINKS
03-19-2006, 15:51
Hi,
I assume that circuit breaker is the one on the wall inside the
generator compartment. It did not seem to be tripped tho I did switch
it on and off to be sure...no change. I think it is just something
simple like that as most everything I have found wrong (in my
learning curve with the 'White Bird' has been as easy as operator
error most of the time. It's hard to see and get back to that breaker
box and I cannot seem to get it completely open, are there just the 2
connected breakers?
Thanks so much for the help.
I will check the wires on back of the motor tomorrow and look for
corrosion and try to reset those breakers again just to be certain.
Rose Mary
82 FC 33
Oregon -warm & sunny today!
you will have no power to make your fan turn. Ernie-83pt40 in Texas
> From: Rose Mary
reset
> button trips.
> thanks
> Rose Mary
> 82 FC 33
> week.....
> Yahoo! Groups Links
03-20-2006, 00:37
Rose Mary- the control box behind the generator engine is the unit I was talking
about. You might have to air the coach up to extend the generator tray. My box
use to trip those breakers every once in a while. Ernie 83pt40 in Texas
Sent: Mon, 20 Mar 2006 03:51:41 -0000
Subject: [WanderlodgeForum] Re: Kohler genset tripping
Hi,
connected breakers?
Rose Mary
82 FC 33
> From: Rose Mary
reset
> button trips.
> thanks
> Rose Mary
> 82 FC 33
> week.....
> Yahoo! Groups Links
Yahoo! Groups Links
03-20-2006, 01:58
Rose Mary,
On our 1987, in order for the generator system fan motor to run (turn),
it needs voltage, which the alternator (the Kohler unit) should provide.
The fan will not turn if the voltage is not present. On ours, it turned
out the Kohler unit was bad, not putting out the voltage due to corroded
windings, etc. I replaced the Kohler with the Newage unit. I suggest
having a reliable generator shop test your system.
> button trips.
> thanks
> Rose Mary
> 82 FC 33
> week.....
> SPONSORED LINKS
sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O\
bWmSYTw>
> Wanderlodge
<http://groups.yahoo.com/gads?t=ms&k=Wand...2=Wan\
derlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea\
tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>
Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34\
cC1O9CxA>
r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY\
HfELr6o72IW1A>
<http://groups.yahoo.com/gads?t=ms&k=Used...onal+\
vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer\
&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-\
kXbDI4ZSadEw>
<http://groups.yahoo.com/gads?t=ms&k=Auto...ehicl\
es&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us\
ed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq\
_4GlXA>
> YAHOO! GROUPS LINKS
