Sending Units for Kohler/Yanmar 12.5
08-01-2005, 02:54
Does anyone know the part numbers for the oil pressure & water
temperature sensors for a Kohler/Yanmar 12.5 (engine model
#4tn82e-uk)?
This is Kohler model #12.5CC067.
I have ordered from a Kohler dealer but keep receiving the shutdown
switches.
Bill & Rita in Roanoke, VA
1987 FC-35
08-01-2005, 13:31
Bill and Rita,
I checked my service manual, and it looks like the part numbers are:
Oil pressure switch: #256530
Water Temp switch: #252752
The manual also shows "switch, water temperature", with a part #258694, and
I can't tell which one is used.
Let me know if this doesn't help...I'll investigate further if necessary.
Kevin McKeown
Yorba Linda, CA
1986 38' PT
12.5 Yanmar/Kohler 4TN-82E
08-01-2005, 20:50
Kevin, Thanks for the info on the sending units, In addition to the
incorrect parts received from the Kohler dealer I also received a oil pressure
switch
from BB with the wrong size
threads.
The numbers you have provided should help us finally resolve the issue.
Thanks again,
1987 FC-35
