1985 PT36 @ Craig's List 04-22-16
04-23-2016, 01:01
F.Y.I.
http://rochester.craigslist.org/rvs/5547190612.html 23 Pictures, White/ Blue & Grey. $12.5K in Rochester, NY. "If you are reading this post, it is still available. installed (4) brand new heavy duty batteries on 10/7/15. Repair of faulty coolant line on 4/19/16. This bird is mechanically sound as it sits, ready for the road & needs to be driven. This bus is full of potential but is in need of some TLC & is essentially a project on wheels. The things found in need of attention are: -Air bags are dry rotted and will need future replacement. -Replace heater & coolant hoses will need future replacement. -Generator can not be started to test the 120 VAC systems -Various lights on the coach did not function. -Hydraulic system unable to activate the levelers and the generator slide. -Visible Existing Damage to A/C Shroud See repair estimate from Caledonia Diesel 585.538.4395. $4650.00 Total estimated cost of repairs per 12/1/2015 inspection. New asking price of $12,500. reflects needed repairs & other unknowns. -A/C compressor supplying cockpit air also inoperable. OR Reasonable Offer. Must sell as part of an estate, No Leans. We Can email you a Video of engine running. Also video footage of full interior. This 1985 36Ft 220,000 K mile Equipped with Kohler generator 12.5 RV Alloy rims with lots of near new tread non matching tires. (4) New Kelly KDM 11R22.5 G purchased, 5/4/2011. This coach has been stored outside in a residential driveway for one year. Prior to that it was driven to & from Florida annually. Most recent owner is deceased. Blue Box Included. Contact info: 585-993-1201 585-409-1079 Maintenance, repair records, improvements or upgrades: The Blue Box contains reference repair binders, owner manuals & repair records. Allison transmission was rebuilt by W.W.Williams Columbia, SC in April of 2007. Most other repairs were general & preventative maintenance from normal wear & tear. All inclusive with sale of coach. Blue Box Included." Frank DiLaura Learning Everything (a.k.a. "M.T. Nester") |
04-24-2016, 09:15
(This post was last modified: 04-24-2016 09:15 by oldmansax.)
RE: 1985 PT36 @ Craig's List 04-22-16
Someone over on the other board went to see this and it has been discussed there. General opinion is it's a project. Since we sold ours, we are going up to look at it. I'll keep you all posted.
TOM |
04-29-2016, 09:31
Update
We didn't go look at this coach because someone bought it sight unseen. TOM |
