Flourescent light issue
03-16-2010, 21:21
I have an issue with the front interior flourescent lighting on an '86 PT40.
There are three switches over the entry door that control the flourescent lights
in the forward area of my bus.(Over the sofa, and side mini-desk salon area).
These lights will not work for long periods of time at all, then suddenly work
fine for a long period, then back again to inoperative.
I'm trying to determine if they all run off a SINGLE ballast. If so, that is
probably my problem, if they're all independantly ballasted ... then I have an
intermittent short of some sort to run down.
The exterior light that runs off the same power loop works fine all the time,
but those are incandescent so ....
I've discovered many time that a simple ground issue kills lights.
Anyone dealt with the ballasts in this part of the bus ? One ? Three ?
Where is it ... and what contemporary model number is it if it's just one ?
I'd like to fix it the first time I have to tear that open ...
03-17-2010, 01:04
I have the same problem and took the switches out to expose the wiring. Found out that a butt connector was loose. Sometimes I would pound my fist by the switches and that would jar the butt connector.
83PT40
Wanderlodge
Weatherford, Tx 817-475-3991
--- On Wed, 3/17/10, zboy59 wrote:
Subject: [WanderlodgeForum] Flourescent light issue
Date: Wednesday, March 17, 2010, 3:21 AM
There are three switches over the entry door that control the flourescent lights in the forward area of my bus.(Over the sofa, and side mini-desk salon area).
These lights will not work for long periods of time at all, then suddenly work fine for a long period, then back again to inoperative.
I'm trying to determine if they all run off a SINGLE ballast. If so, that is probably my problem, if they're all independantly ballasted ... then I have an intermittent short of some sort to run down.
The exterior light that runs off the same power loop works fine all the time, but those are incandescent so ....
I'd
03-17-2010, 01:23
I had a similar problem in my 85 PT40. It turned out to be a canon connector. The connector is a large (1 1/2 - 2") and can be found by removing the back panels in the overhead cabinets. I found my problem by emptying the passenger side cabinets and removing the panels aft of the mini-desk area. The contacts within the connector become slightly corroded and/or loose. Undo the connector and check the contacts and clean. You may also have to bend a contact or two to make the connection.
Hope this helps.
Jerry
85 PT40
Sent via BlackBerry from T-Mobile
Date: Wed, 17 Mar 2010 08:21:32 -0000
To:
03-17-2010, 06:53
one ballast for each light
Stephen 97 BMC 35
77 fc for sale
area).
03-19-2010, 20:11
Thanks guys !
Now that I know it's not the ballast ... I can trace wiring. I've had the switch
bank apart and found nothing there. Must be wiring elsewhere.
Marty
86 PT40
Kalamazoo
> Stephen 97 BMC 35
> 77 fc for sale
area).
04-04-2010, 05:33
Look for an intermittent molex plug
Gary
85pt40
--- On Sat, 3/20/10, zboy59 wrote:
Subject: [WanderlodgeForum] Re: Flourescent light issue
Date: Saturday, March 20, 2010, 3:11 AM
Thanks guys !
Now that I know it's not the ballast ... I can trace wiring. I've had the switch bank apart and found nothing there. Must be wiring elsewhere.
Marty
86 PT40
Kalamazoo
> Stephen 97 BMC 35
> 77 fc for sale
