Step Cylinder
04-17-2005, 10:12
Step Cylinder
My entry step in my '82 FC 35 works very "jerkily" and intermitantly.
There is a lot of air leaking towards the back of the step from around
the cylinder. Should I replace the cylinder or is it worth
rebuilding? Any part numbers and sources for rebuild kits or new
cylinder would be appreciated.
Thank you.
Steve Johnson
Grand Rapids, MI
'82FC35
04-17-2005, 10:21
Step Cylinder
Gene you might check a couple of things.
1. For some strange reason the factory could not explain my 1982 FC35 does
not nor has it ever had the two microswitches that turn the step on and
off. Mine has one microswitch that only turns the dash light on and off.
You might check if your coach has the two switches. They will be located on
a vertical part of the step towards the back. One of them has a dual
purpose to turn the light on and off on the dash when the step is extended
or retracted.
3. The two solenoids turn the air off to the air solenoid when the step is
extended or retracted. When you view the two switches (if you have them)
you can tell which is which.
3. You can remove the air soldnoid at the back of the step and take it
apart and clean it thoroughly and then replace the O rings. Put it back
together.
4. . If you have the two microswitches and they are adjusted properly then
your step should work now.
5. If it still leaks and you do not have the two microswitches then you
need to install them. The wiring is easy. If you need help I can tell you
how to wire them.
Tom
1982 FC35
In the beautiful Mohawk Valley.
>Thank you.
>Steve Johnson
>Grand Rapids, MI
>'82FC35
04-17-2005, 10:32
Step Cylinder
It's a great idea to disconnect the cylinder from the step assembly so you can
cycle it with out the real danger of the step kicking your butt.
Mike Hohnstein
Germantown, WI
Sent: Sunday, April 17, 2005 5:21 PM
Subject: Re: [WanderlodgeForum] Step Cylinder
or retracted.
together.
how to wire them.
Tom
1982 FC35
>Thank you.
>Steve Johnson
>Grand Rapids, MI
>'82FC35
Yahoo! Groups Links
04-17-2005, 10:42
Step Cylinder
I do not believe a repair kit is available. I ahd the same problem with my
84 PT 40 last year and I took the numbers off the exixting valve, called a
company that ahndle npnuematic valves and bout a direct replacement for
$110. plus shipping. not at home so cant help by giving info on direct
replacement numbers.
Harv
To:
Sent: Sunday, April 17, 2005 5:12 PM
Subject: [WanderlodgeForum] Step Cylinder
> Thank you.
> Steve Johnson
> Grand Rapids, MI
> '82FC35
> Yahoo! Groups Links
> Checked by AVG Anti-Virus.
> Version: 7.0.300 / Virus Database: 266.9.15 - Release Date: 4/16/2005
No virus found in this outgoing message.
04-17-2005, 14:46
Step Cylinder
My 82 only has one switch also. There is no retract lock so I would expect
that they would keep air on the cylinder.
- Chuck Wheeler -
82 FC31 - Fort Worth, TX
-----Original Message-----
[mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Tom
on
or retracted.
together.
how to wire them.
Tom
1982 FC35
>Thank you.
>Steve Johnson
>Grand Rapids, MI
>'82FC35
Yahoo! Groups Links
04-22-2005, 01:45
Step Cylinder
I have a problem with my step, it will not retract. I have both
switches in the correct position, and full air pressure, and nothing
happens when I close the door. Any suggestions?
Jim
1991 34' SP
--- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler"
expect
> - Chuck Wheeler -
FC35 does
on and
and off.
located
> on
extended
> or retracted.
step is
have them)
back
> together.
properly then
then you
tell you
> how to wire them.
> Tom
> 1982 FC35
around
> >Thank you.
> >Steve Johnson
> >Grand Rapids, MI
> >'82FC35
> Yahoo! Groups Links
Service.
04-22-2005, 01:48
Step Cylinder
Jim, On our 88 WB40 we had the same problem and I took the air switch apart and
cleaned/ lube and that seemed to do the trick. At time will not work with low
air, however works good when it gets air.
Bryan Altier
Greenville, SC
88 WB40 "Xanadu"
Sent: Friday, April 22, 2005 9:45 AM
Subject: [WanderlodgeForum] Re: Step Cylinder
Jim
1991 34' SP
expect
> - Chuck Wheeler -
FC35 does
on and
and off.
located
> on
extended
> or retracted.
step is
have them)
back
> together.
properly then
then you
tell you
> how to wire them.
> Tom
> 1982 FC35
around
> >Thank you.
> >Steve Johnson
> >Grand Rapids, MI
> >'82FC35
> Yahoo! Groups Links
Service.
Yahoo! Groups Links
04-22-2005, 03:28
Step Cylinder
Jim
Some SP36 coaches' steps won't retract if the "electronic master switch" is
in the off position,defaulting it to extended.
Fred & Jeanne Hulse
Morristown Arizona
1997 Wanderlodge PT41
