Samsung Refrigerator for 2001 LXi
03-11-2019, 21:47
Hi
Hopefully some one can help me to go in the right direction. In my 2001 LXi I currently have a Dometic refrigerator. It works OK but I would rather have something with more features - frost free etc.
My research so far says the Samsung is the best way to go. I have several questions:
1-What current model would be the best?
2-How hard is the installation?
3-How pleased are you guys that made the conversion?
4- I was told I may have to remove the windshield to get the Samsung in the coach.
5- Does the working Dometic have any value.
I appreciate the help
Thanks
Urnie
Urnie & Medie Krueger
Yorkville, IL
2001 LXi One Slide
1983 FC35 sold
03-12-2019, 07:23
RE: Samsung Refrigerator for 2001 LXi
Hi Urnie,
I think this depends completely on your space available, there are some very comprehensive threads on this on Gurus.
It is not a weekend project, but can be done if you are handy.
Best upgrade we have done to the coach, the best!
Don't know.
Not really.
Gregg
Gregg & Jane Gesse
1994 WLWB 40 Mid-Door
03-12-2019, 07:41 (This post was last modified: 03-12-2019 07:42 by ernie ekberg.)
4- no thru the door- remove copilot chair
5- 18 years old- if it has removable front panels- those maybe worth something, otherwise, junk it
03-12-2019, 22:49
Thanks Ernie
I will check the threads on Gurus.
My Dometic does have removable front wood panels. Any idea of possible value?
I will do some measuring to see how hard it would be to remove and install. The Samsung seems readily available so I should be able to remove the old - measure - and install.
When you installed your did you just use molding to keep in place or a few screws?
Thanks again for the help.
Urnie
Yorkville, IL
2001 LXi One Slide
1983 FC35 sold
03-13-2019, 07:48
Look for this thread
'Time to replace defective and potentially dangerous absorption fridge'
Gregg
Gregg & Jane Gesse
03-13-2019, 08:23
I helped a friend install it in his Lxi. He fastened it on top, bottom and rear thru the vent.
what made it "easy" was that we had it the same level as the stepwell slide, so that we could slide it in and up to clear the curve in the dash
03-13-2019, 08:23
03-13-2019, 23:50
Thanks Ernie
Great information - lots to think about.
Urnie
Yorkville, IL
2001 LXi One Slide
1983 FC35 sold
03-13-2019, 23:50
Thanks Ernie
Urnie
Yorkville, IL
2001 LXi One Slide
1983 FC35 sold
03-13-2019, 23:51
Thanks Ernie
Urnie
Yorkville, IL
2001 LXi One Slide
1983 FC35 sold
