Generator Switch Box
03-06-2013, 11:53
Post: #21
RE: Generator Switch Box
(03-06-2013 09:51)davidmbrady Wrote:  Hish,
It's interesting the way BB did it over the years. On my LXi both the bedroom and the living room AC's are wired to just one of the inverters, so I get to choose which one I'd like to run, but I can't run both. It makes sense cause it prevents overload of the 50DN alternator (which is good for 300A as you know, and it's rated to output that power continuously). Dometic recommends 3500W of power per air conditioner.
David,
You and the other LXI owners are lucky to be able to run 1 on an inverter. The inverters in the 95 are 2500 watts each so if what happened to you in the desert happened to me........hot would be an understatement!Angel FWIW by middle and back AC's are on 1 leg, the front is on the other leg.
Pete and Donna Chin
95 42' WLWB
On The Road Always! :-)
-Toby Keith & Willie Nelson
03-07-2013, 13:34
Post: #22
I can run all three cruise airs on mine with the genny no problem.
