A low-tech way to quiet down an FC generator - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: A low-tech way to quiet down an FC generator (/showthread.php?tid=4093) |
A low-tech way to quiet down an FC generator - Scott Forman - 01-01-2007 11:55 Happy New Year everyone, I have had my FC for about 2 years now, and in that time, one of the few things I have disliked about it is the amount of noise the generator creates in the porch area. I use my coach primarily for college football, which means that I am rarely on hook-ups. The gen noise has really been a draw back to me as I'm sure it is to you. I have made good progress at quieting it down by re-insulating the compartment inside and readjusting the door so that it fits snug...these changes have helped reduce the engine noise down to a reasonable level. What I hadn't been able to change, though, is the jet-engine like racket created by the radiator fan sucking air in through the intake grill. You FC owners know it is deafening. I considered several fixes, from John Finn's radiator/fan relocation to springing the bucks for a new Onan Quiet Diesel. Instead, I have solved it for about $30 in materials and 2 hours of work. I have built a "sound deflector". I took a piece of plywood and cut it 20" wide by 35" high. The 20" is the approximate width of the intake grill, and the 35" allows me to place the board on the ground 6 or 8 inches out from the coach and lean it in to the side just above the intake grill. I finished the plywood on all sides to make it waterproof and added a strip of rubber at the top edge so that it wouldn't mar the paint where it leans to. Then, to the back side that faces the intake, I stapled some of the pyramidial acoustical foam used in recording studios and radio stations...this absorbs sound that hits it instead of reflecting it. The end result is amazing. The sound from the air intake is now virtually nonexistant. Airflow is not a problem, as the sides are still open to allow air to flow in to the grill. The acoustical foam is the key, all the sound that hits it is killed...without the foam, it would still be quieter, but not nearly as much. If you are bothered by the noise, try this fix, it is simple & cheap, so if you don't like it, you haven't lost much. You could easily paint the board to match your coach color and it would hardly be noticable. Email if you have any questions or would like me to snap a picture for you. Scott Forman 82 FC35RB Memphis A low-tech way to quiet down an FC generator - one_dusty_hoot - 01-01-2007 14:22 Hi Scott, What you have done would make a good project contribution to the files section with a few pictures in the photo section if you care to do this. Maybe someone will be looking later and what you did is just right for them as well. bob janes, greenville, sc --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Happy New Year everyone, > > I have had my FC for about 2 years now, and in that time, one of the > few things I have disliked about it is the amount of noise the > generator creates in the porch area. I use my coach primarily for > college football, which means that I am rarely on hook-ups. The gen > noise has really been a draw back to me as I'm sure it is to you. > > I have made good progress at quieting it down by re-insulating the > compartment inside and readjusting the door so that it fits > snug...these changes have helped reduce the engine noise down to a > reasonable level. What I hadn't been able to change, though, is the > jet-engine like racket created by the radiator fan sucking air in > through the intake grill. You FC owners know it is deafening. > > I considered several fixes, from John Finn's radiator/fan relocation > to springing the bucks for a new Onan Quiet Diesel. Instead, I have > solved it for about $30 in materials and 2 hours of work. > > I have built a "sound deflector". I took a piece of plywood and cut > it 20" wide by 35" high. The 20" is the approximate width of the > intake grill, and the 35" allows me to place the board on the ground > 6 or 8 inches out from the coach and lean it in to the side just > above the intake grill. I finished the plywood on all sides to make > it waterproof and added a strip of rubber at the top edge so that it > wouldn't mar the paint where it leans to. Then, to the back side > that faces the intake, I stapled some of the pyramidial acoustical > foam used in recording studios and radio stations...this absorbs > sound that hits it instead of reflecting it. The end result is > amazing. > > The sound from the air intake is now virtually nonexistant. Airflow > is not a problem, as the sides are still open to allow air to flow in > to the grill. The acoustical foam is the key, all the sound that > hits it is killed...without the foam, it would still be quieter, but > not nearly as much. > > If you are bothered by the noise, try this fix, it is simple & cheap, > so if you don't like it, you haven't lost much. You could easily > paint the board to match your coach color and it would hardly be > noticable. Email if you have any questions or would like me to snap > a picture for you. > > Scott Forman > 82 FC35RB > Memphis > A low-tech way to quiet down an FC generator - Scott Forman - 01-01-2007 14:52 Good idea. Will put that on my "to-do" list Scott --- In WanderlodgeForum@yahoogroups.com, "one_dusty_hoot" > > Hi Scott, What you have done would make a good > project contribution to the files section with > a few pictures in the photo section if you care > to do this. Maybe someone will be looking later > and what you did is just right for them as well. > > bob janes, greenville, sc > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > wrote: > > > > Happy New Year everyone, > > > > I have had my FC for about 2 years now, and in that time, one of > the > > few things I have disliked about it is the amount of noise the > > generator creates in the porch area. I use my coach primarily for > > college football, which means that I am rarely on hook-ups. The > gen > > noise has really been a draw back to me as I'm sure it is to you. > > > > I have made good progress at quieting it down by re-insulating the > > compartment inside and readjusting the door so that it fits > > snug...these changes have helped reduce the engine noise down to a > > reasonable level. What I hadn't been able to change, though, is > the > > jet-engine like racket created by the radiator fan sucking air in > > through the intake grill. You FC owners know it is deafening. > > > > I considered several fixes, from John Finn's radiator/fan > relocation > > to springing the bucks for a new Onan Quiet Diesel. Instead, I > have > > solved it for about $30 in materials and 2 hours of work. > > > > I have built a "sound deflector". I took a piece of plywood and > cut > > it 20" wide by 35" high. The 20" is the approximate width of the > > intake grill, and the 35" allows me to place the board on the > ground > > 6 or 8 inches out from the coach and lean it in to the side just > > above the intake grill. I finished the plywood on all sides to > make > > it waterproof and added a strip of rubber at the top edge so that > it > > wouldn't mar the paint where it leans to. Then, to the back side > > that faces the intake, I stapled some of the pyramidial acoustical > > foam used in recording studios and radio stations...this absorbs > > sound that hits it instead of reflecting it. The end result is > > amazing. > > > > The sound from the air intake is now virtually nonexistant. > Airflow > > is not a problem, as the sides are still open to allow air to flow > in > > to the grill. The acoustical foam is the key, all the sound that > > hits it is killed...without the foam, it would still be quieter, > but > > not nearly as much. > > > > If you are bothered by the noise, try this fix, it is simple & > cheap, > > so if you don't like it, you haven't lost much. You could easily > > paint the board to match your coach color and it would hardly be > > noticable. Email if you have any questions or would like me to > snap > > a picture for you. > > > > Scott Forman > > 82 FC35RB > > Memphis > > > |
